In reading the instructions in an ARF I had it said.
After opening the covering around the hinge slots it said to drill a small hole (don't remember what size hole) in the center of the hinge slot to act as a channel to allow the CA to fully contact the entire hinge. Made since to me as just applying CA to the hinge gap and allowing to wick in would only allow CA to go a small distance into the hinge. Is there any merit to this method?
And by the way, debonder will clean up CA even after it has cured so there is still hope with that wing you dripped on
