RCU Forums - View Single Post - Nexstar with flaperons
Old 05-20-2006 | 07:00 AM
TigerTail's Avatar
TigerTail
Default RE: Nexstar with flaperons
It sounds like I need to buy anothe servo and do flaps. I would assume the flaps will make the plane land the same way it did with the air brakes that came with it, assuming I had the flaps down! So if I do the flap option, the ailerons are now shorter. Do I need to increase the aileron throw to compensate for having less surface area to work with?
