The failsafe will only tighten the brakes as tight as you can normally brake without it. (you prob already know that tho[sm=spinnyeyes.gif]) Make sure the setting for your brakes is regularly (Under use) tight or locking up, then rebind and make sure you hold the brake lever all the way up till bound - Hope this works -
