RCU Forums - View Single Post - FAI Fuels and Paint
Old 05-20-2006 | 06:32 PM
jetpack's Avatar
jetpack
Default FAI Fuels and Paint
I know there's been much discussion on nitromethane and paints, but here's my question...
I am a new powerboat builder and looking to just run FAI fuel. The motor that I have is more set up for it than it is for nitromethane, believe it or not (high compression webra).
This is just fine with me, because as a boat builder we are faced with using epoxy paints to hold up under high nitro fuels and waterproofing. Or faced with using fiberglass and resins, which technically speaking does not work well on keeping well formed corners, inside and out on the bottom of a hydroplane hull for example.
If I am running straight methanol and oil, what would be my choices for a finish? Would Spar Varnish hold up? I want to keep a clear finish on most of the hull, and just use trim colors by the seams to hide the laminates. What would be a durable finish without going through the task of using all epoxy (tough sanding and blushing).
I thought about using just spar varnish and model enamels, would this work? How bad is just methanol on paints?
(PS: I am refering to plywood hulls - not fiberglass or ABS)
