RCU Forums - View Single Post - Bill Evans Simitar
Old 12-21-2002 | 02:12 AM
de-kitter
Default Bill Evans Simitar
pulquijet.....
Most all of the Bill Evans wings are very much alike. I believe you could use either the Desperado or the small Scimitar wing profiles on your Scimitar 540. The smaller one is a bit thinner, so if you are going fast, add a few strips of carbon fiber under the sheeting. If the fuse does not match exactly, shim it or cut it.
The balance is not critical, just start off with about 1/8 inch of "up" in each aileron, and fly it.
The offer still stands, let me know if you want the jpg files of the root and tip.
