RCU Forums - View Single Post - Gen LE Third Gear ??
Old 05-21-2006 | 11:22 AM
24Deman
Default Gen LE Third Gear ??
I have it shifting into 2nd at about 20 -25 ft. This thing is doing great, but won't shift into 3rd. I run mainly at a short track and around my house, so third isn't that important. But if you have it why not try it. I turned the screws at 7 1/2, and got no shift. Temps around the 210 mark, than I tried 8 turns out and still no shift. When I went to check the screws they were loose almost coming out. So I tighten them up to about 7 turns where they wouldn't fall out and said the heck with it. Does anyone else have a problem with it shifting to third? Also have you had the screws loosen that much. Thanks
