RCU Forums - View Single Post - Diesel starting techneque
Old 05-21-2006 | 03:27 PM
Motorboy's Avatar
Motorboy
Default RE: Diesel starting techneque
The wet engine make difficult to start the engine.
Remove all fuel from engine, back off the compression screw 1 turn up. Give the engine some drops of fuel in carburator and in the exhaust port. Close the main needle and open about 3-4 turn.
Flip the engine fast as possiple to get generate hot of compresion. While fliping the engine increase compresion 1/8-1/4 turn between 8-10 flips. it will ignite when the compresion are in right position. While engine are running, increase compression to max rpm, then lean out until the engine blurbing and screw back about 1/2-1 turn.
Overcompressed engine will loose rpm and sound hard work, back off and the engine will run fast.
Jens Eirik
