RE: How to hook up this tailwheel?
The spring is what steers the tail wheel from the rudder, the clevis is attaches the spring to the rudder. the pin with the hole is where the spring fastens to the tailwheel and also adjusts the possition of the wheel. use mild tension on the spring and the assembly will follow the rudder with no damage to rudder and hinges.
