RE: Fancy a FunFactor 6061 ARO chassis?
Hey Poorjudgment…
Not a problem. I understand. I’ve also been very busy with my day job (travel) and with the preparations of a new baby. At the moment, I don’t need you to revise the drawing. Since I have a front case… I moved the holes to center, and in the correct spot. I don’t know if the conversion process moved the holes, (2D to 3D) or if you saved it that way. Either way, it’s not a big deal.
To all…
I’m going to try to do the CAM code tonight… and if the 6061 stock shows up… I should have the first one cut in a few days. I will post pictures soon
