RCU Forums - View Single Post - BME 37% Ultimate
Old 05-22-2006 | 08:16 PM
  #40
Thunderbolt47's Avatar
Thunderbolt47
My Feedback: (8)
Default RE: BME 37% Ultimate
Hey Guys, I thought you might like to know that on the top wing I ran the servo ex. down the wing and cut a hole in each wing at the inside bottom. I plug the servo in to a modified ernst charge jack, like on the GP pitts. All I did was to take a long rod and punched out a hole in the rib next to the servo bay. It's opened all the way through to that rib. It is a lot simplier than running it down the outer stuts.
Also I cut a 1 inch square hole in the end of the bottom wing and used my soldering gun with a wire bent square to fit the hole. I then cut a 2in deep hole. I leave the extention hanging out of the fuse. when I slide the wing on, just plug it in , safty clip it and tuck it in the pocket.
BTW my canopy was cracked also. Max sent out another one no question asked. I also had two left elavators. I E-mailed a picture to max and he sent me one right out.
