RCU Forums - View Single Post - Help!!!!
Thread: Help!!!!
Old 05-22-2006 | 10:29 PM
Connormon
Default RE: Help!!!!
make sure there is fuel in the fuel line. To ensure that your glow plug is charged, take your large cross wrench out and remove the glow PLUG, then press the tip of the glow plug into the glow ignitor. If you glow ignitor/stick is working the coil inside the glow plug (on the bottom) should light up bright orage/red. Also Are you able to pull the pull start?
If there is no fuel in the line you can either detach the line from the carb (where it attaches on the engine) and siphone or suck on the line and when the fuel gets about an inch from your mouth, pinch it and place it back on the carb. Pull it a few times and it should start making a sound which is noticable and will tell you that fuel is going into the engine. Also try placing a few drops of fuel into the carb. To do this remove your air filter and using your fuel bottle just drop 2-3 drops into the carb, pull the pull start up a little and the fuel should dissapear.
If you cant move your pull start post it up and i will tell you another option.
If any of these things dont work post it up, and ill think of what else is happening.
Welcome to the nitro world, as well as these forums.
