Maidened my new Seagull Decathlon !
Installed an OS .46AX and found that this engine has wayyyyy more than enough power for the airplane. With this engine the plane balanced perfectly. Installed a Bisson Pitts muffler as the AX muffler is too wide to install in the fuse cut-out. Only have two flight on it so far but am waiting to see what I can do with it. The plane is definitely a performer. Typical Cub-like beast in ground handling and it definitely wants to snap if you lift off before the plane wants to fly. Once in the air it is incredibly nimble and, until you are used to it, recommend low rates as the control surfaces are extremely effective. No way would I consider a gyro as some have done. This is definitely a fun plane and hope to enjoy it for a long time to come! My H9 J3 Cub is going to get a rest for awhile.
