You'll Go BLIND![8D] All you gotta do is put your finger over the exhust and pull one or two times with the glow ignitor off. This forces all the pressure into the tank to prime. Methanol is bad pioson don't get it in your mouth or skin for that matter.
OOHH pull the fuel line off the carb.you should get fuel outta the line if it's primed. Bee careful not to flood the engine. If the pullstsrt gets hsrd to pull STOP! remove the glow plug and pull the starter to clear out the fuel in the cylinder. If you don't you'll be buying a new pull start or worse a new engine![X(]
