RCU Forums - View Single Post - 11x5 Prop Same Size As 11x6
Old 05-23-2006 | 02:16 AM
zain
Default RE: 11x5 Prop Same Size As 11x6
This one test you can do.
Check your rpm with each props installed in the engine and if the rpm decreases when you put in the new prop then it is not the same prop if the rpm remains the same at full throttle then it is the same size prop.
What kind of trouble are you having.
zain
