RE: ST 2300 fuel delivery problem
If you can't get your fuel tank higher, so that the centerline of the tank is no more than 3/8" or so lower than the center of the carb, then we would suggest a pump or pressure/regulator system. The fact that the tank's so low is the source of your fuel feed difficulties.
