RCU Forums - View Single Post - 2nd fan explodes in three weeks
Old 05-23-2006 | 04:29 PM
Marty O
Default RE: 2nd fan explodes in three weeks
Have never seen one of Tom's JMP Dynamax ever come apart. This unit is tested far above anything your OS will ever acheeve.
I agree with the others that something is array. I think you should send the whole unit into Jet Model Products for inspection and set-up. Then also have someone check the engine runout .
Is this a unit that has the blades repitched? The heat they use to repitch will make the carbon fibers delaminate from the matrix and cause failure.
I still would send it in for a going over .
Marty O
