RE: TF Spitfire Build (Gold Kit)
yes I did the bend the stubs as I added the struts as a after thought I had to do a little extra work to get them to fit in after starting with the wire gear. the bend is so the plane has less nose over tendancy seems to help a bit if you havnt closed the wing in you might want to incorporate it into your gear trial and error , I wish I had started with the struts in the first place they look so much better
