RCU Forums - View Single Post - Choise of carburettor
Old 05-24-2006 | 08:44 AM
BillS
Default RE: Choise of carburettor
ORIGINAL: jmj
I have several engines to be converted;
3 Toro 25 double barrel
1 Toro 25 single barrel
1 Weedeater 21cc
1 Stihl 40CC
I want to replace the carburettors on all engines, i dont want to mess with rebuild kits.
I want all the 25cc and the 21cc to use the same type of carb.
I guess the 40cc will need a bigger carb.
I do not know much of carburettor models and numbers, so i want some input of what carbs i can use.
It should be a well known type that is easy to set up, and with 2 needles.
Thanks.
Simply buying and replacing carbs will not solve many problems. You will be disappointed. To be successful with conversions it will be necessary to understand at least the fundamentals of how the carb works.
Bill
