ORIGINAL: basimpsn
First set the flap switch to the center then setup your flap to the first position default. Next step is to set the switch to ELEV position using the mix program to trim the flaps to neutral. After setting the neutral & first position flaps now put the switch to land position and repeat the second step for full flaps.
Am I to use a program mix to make this adjustment or should it be the landing program?
