RE: BRIO Electric 10-size
33.4 ozs AUW with Eflite Power 10, Castle Phoenix 45, 2100 TP Prolite. Only mod, was using 2-1/16" wheels from Hobby Lobby and NMP aluminum axles from Central Hobbies. No wheel pants. Rear mount elevator and rudder servos. JR 241's all the way around. JR 610 RX. 2- 12 inch JR extensions. This is the heaviest of the recommended setups. CG is just about right on the wing spar(front edge of recommended CG with Lipo right over landing gear). One flight so far. Seemed to fly OK considering it was really windy. Unfortunately, had to deal with the typical warped surfaces and a slightly warped wing panel just like a lot of people have been getting. Plenty of vertical pull. Will probably prop down from 12X6 APCE though (41 amps static). Initial impression is even at this weight it will fly just fine. Control surfaces were all setup to what I would typically use on a 2M pattern setup on the low rate for starters.
