RE: WHAT A DEAL
Bills: Have you determined the best exhaust timing? And if you use that timing....is making the exhaust port any wider going to help? I am returning that bad shaft engine because it has another problem also. If I was to fix it...I would just go to a little bigger carb or take a shaft out of another dead carb.
