RCU Forums - View Single Post - problems with the jr quatro system
Old 05-24-2006 | 09:21 PM
andrew66's Avatar
andrew66
Default problems with the jr quatro system
Hey, i bought a JR quattro 4ch system in the winter, and have been flying with it for about a month. just the other day, i noticed something horribly wrong when i turned my plane on.....the controlls would just randomly glitch (kinda like it was having a seizure). i then quickly turned the system off. i checked the plane and the tx out and found nothing to be wrong (batteries were fully charged and working) i turned the model on again, and the problem went away.......kinda weird eh? i then discovered that when i turned the model off the throttle was in the closed position, and when i went to turn the model on, i noticed that i must have bumped the throttle stick to half. sooooo....i moved the throttle to closed and turned the plane on, everything works perfectly (i did range check), and when i turn the plane off, and move the sticks to a different position and turn the plane on, the glitching happens.
have any of you guys heard of this, or am i the one in a million guys that this happens to. i did contact JR and they never heard of this happening, or any other places i called. i ruled out the servos and the flight pack, b/c im using them with a futaba radio and reciever and everything works perfectly.
right now, im a little hesitant of sending my radio in, b/c its going to cost me $50 to send it, and it will be gone for a month. i would just use the system ive got now, but im moving to alberta in the middle of june, so i will be out of a radio. is there some way to fix this, or should i buy a new system?
any input would be greatly appreciated.
thx,
andrew66
