RE: SkyFly, T-hawk
1) Does the plastic around the motor seem deformed, like the motor moved?
2) Check the boom that holds the tail. Can you move it around at all, or rotate it. It should be solid
3) If it can be moved, does the tail seem do droop down a bit if you look at it from teh side? The boom should go straight out from the body, not sag toward the rear.
Perhaps you can post some photos.
