RE: Firebird Freedom
I am not sure why this happened. I will try and ask my friends.
***Did you guys range check the equipment before flying? With the Antenna down, 30 steps away and such.......***
I don't think the following apply in your case, but here we go:
These planes are on 27Mhz. there is only 6 channels, from ch1 through ch6.
There are many toys on these same channels, so I wonder if there were other people on the same channels.
Another thing when my batteries were low(very empty), I have seen some freaky things. Were your batteries low, very low?
This has been the case in my room, (after the motor had been cutoff and I landed), I had the battery plugged in while adjusting some control surfaces and there was so little voltage left that the servo's started freaking out. Seen this more than once.
Let me know and I will try and ask my brother who has more experience with the same exact plane
Gryphon
