RCU Forums - View Single Post - blades?
Thread: blades?
Old 05-25-2006 | 03:22 AM
twistercp
Default RE: blades?
have you got too many washers so the head bolts are not tight enough?
test by seeing if the blade grips have play along the shaft.
maybe put loctite or get new blade grip shaft/bolts.
the tail pops off if rubber is not tight enough - get new [longer] bit of rubber
but if you keep bashing the tail then this bit of rubber is probably saving your
motors/tail.
