RCU Forums - View Single Post - Composite ARF Impact
Old 05-25-2006 | 06:24 AM
  #729
Malcolm H's Avatar
Malcolm H
Default RE: Impact
Wing Incidence - adjust to get the fuselage flying at the angle you like.
Tail Incidence - adjust to remove any elevator trim once you have set the CG and done your downthrust checks
CG - mine is on the rear of the wing tube and has a very very slight pull to the canopy in down lines
Engine thrust - My C50 is lined up with the nose ring
What are my incidences in absolute terms? Haven't a clue and don't care! In my opinion you are wasting time adjusting any of this before flying. Fly it then adjust to suit.
Malcolm
