RE: SkyFly, T-hawk
did the prop come off? Can it be put on backwards?
If the plane had plenty of take-off before and not now, something has changed.
Try running the battery pack down then recharge, but at a lower charge rate, if you an adjust it. I don't recall if you can.
If you have a second battery pack, does it give similar results?
