sounds like the carb needs opening more, mine did that with my rush, im not an expert but take the air filter of and hald the brake in, make sure that the carb is not completly closed as this will cause it to die, the only other thing could be the idle needle needs turning up slightly if it stops when you break,
thats all i no myself but worth a try!!
