ORIGINAL: theradioflyer
coming back to a hover with the flat airfoil bades I have a hard time because the head speed is so slow in forward flight, even with the trim all the way up, it wobbles as I try to get back into a hover. Am I trying to get into a hover to quick or is this a flat blade problem and need to switch to sysmetrical blades to keep the head speed up?
www.youtube.com/watch?v=NX-TPgpo1NY
What you are seeing is the airfoil reacting to dead air. While in forward flight you're making your own wind. That's not the appropriate term, but the best I can think of for now. As you slow down you want to slightly increase head speed to maintain the resistance. Even with the syms you'll see some of this, just not as dramatic. The flat blades will give you more stable flight but aren't really made for "fast" forward flight. I think for the amount of time you've spent, you are doing great. Keep it up.
