ORIGINAL: JoshKrenz
Ok thanks.
I havn't really gotten if off the ground too long (it still needs a lot of adjusting). But I finally destroyed the blades. I on accident hit the Idle Up and it all went downhill from there.
I think it's about time to invest in some plastic or carbon fiber blades.
-Josh
P.S. I'm kinda dissapointed in the short fly times. What size batteries work good in the BCP? Or should I just invest in a couple of spare stock ones?
Josh, I put the plastic blades on and I agree totally with chelilim that you start to break much more expensive parts. I put the woodies back on after I bent the main shaft and snapped the boom in half on a crash. Also you will not be sorry if you upgrade the head to the Bell and get the aerobatic upgrade with the new motor. Add a 3s 900 mah-1320mah LiPo and you will love the handling and flight times! I recommend Thunder Power, they are great batteries for the price and the new ones come with balance taps to keep all of the cells in one accord. It's very important to keep LiPo's balanced so they last!
