I belive the pin assignement is differant, but that's a easy fix. U can pop out the pins and rearrange them for the correct polarity. The connectors I believe you can trim to get them to fit, but I could very well be mistaken. Here's a page that migth help on figuring out the pin assignements and the connector fit.
http://www.rcgroups.com/forums/showthread.php?t=392644 Basically, as long as the fit is secure and the correct pin goes in the correct place ur good. You should even be able to buy some new connectors and just scrap the old ones on the servos.
-John
ageexpert posted pretty much same thing. posting at same time
