RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 05-27-2006 | 02:02 AM
  #684
av8tor1977's Avatar
av8tor1977
Default RE: gas fuel with glo plug no ignition
Yep, that's what has been working for us and I recommend you use it. Be prepared to adjust the carb richer for this mixture, and if it won't go rich enough, raise the lever in the carb for the regulator diaphragm a touch.
Good luck, and let us know how it works for you,
AV8TOR
