ORIGINAL:
....Oh I also see that you list the Phoenix 25 ESC to use. Hacker has such an attractive combo on the A20-20L and the X-20 it's tempting. What will I be losing if I go with a Hacker ESC
I fly the SX with a A20-20l and the x20 speed control. It works fine. I am using a Falcon 2200mah battery with HS55's and Electron 6 with the case. The plane will spend most of its time at 1/2 throttle or less. Only time I have used near full throttle was pulling out of a hover at the tail end of the pack.
