RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 05-27-2006 | 10:50 PM
  #4620
gjeffers's Avatar
gjeffers
Default RE: U-Can-Do 3d 46?
Blisster, here is a pic just in case the mental pic isnt comming to ya
here you can see the two 8-32 rods next to the two stock wooden dowls, and where they come out inside the cooling ramp. pretty simple and never failed again.i drilled the holes and tapped with my 8-32 drill and tap set then soaked the rod and filled the hole with 30 min epoxy then screwed them in
