RE: U-Can-Do 3d 46?
I am somewhat experienced in the carbon-fiber push rod, but only in the miniature. That's what they use for the UCD EP foamie. They have these little plastic pieces that CA to the ends of the rods and they (barely, with extreme care) press fit into the control horns (I've since moved to the Dubro mini connectors). They fit so tight that they would bind a bit. They actually squeaked! I had to tap my ail. stick now and then to release the binding and level out! Very durable pushrod for .040" stock. I do have a source for that and other sizes. What sized carbon do you use on this application? Is it glued or tapped into a clevis? Metal or nylon clevis? Fill me in guys, keeps them cards and letters coming! I would enjoy seeing any pics any one might have regarding the actual push rod project they did on the UCD.
I'm lovin' this! When ever I get into to something, I really get into something! Any pertinent info, including pics and video of and about the UCD .46 is highly sought after as I spend these "formative" hours with my Do. You're kind help and advice is appreciated! It's one of the things I have noticed, and generally the same goes for HAM radio operators, of which I am one, advice is plentiful! We are usually little boys in the bodies of grown men and we love to play with and take care of our toys! I might as well do all the beef-up and adjustments while I've got the hood up.
Just to add, I have given this hobby a couple years to see if (1) I could come home, more often than not, with a whole, undamaged airplane and (2) continue to enjoy it regardless (and sometimes because of) the mishaps! I have done both! I and I will do my best to keep you abreast of the progress! Thanks again guys, I feel like one of the bunch already!
Blisster
