ORIGINAL: GarbMan
I contacted the seller. This is what he had to say:
"Hi there,
The receiver itself is single conversion. : )
The range of the receiver you have received is 500m which is same as the one in the pictures. : )"
Is 500M enough range? Can I use dual conversion crystals in a single conversion Rx? Also, what about high band and low band? I want to use a 30 and 46 crystal.
The receiver comes from Hong Kong and has the name "TurBORIX" on it
You need to get the correct crystals for ANY receiver. These RX's are for park flyer use and may or may not work with your transmitter. Maybe these units will work for you. Get the crystals from the seller, if possible. Without more info we, on the forum, can't really help.
Safe Flying!
