ORIGINAL: old n slow
I have a couple question that I know someone can answer.
1. If I charge my tx and rx batteries today and can't fly but can 4-5 days later, will it be safe to fly without putting them on the charger?
>If it was my plane, I would recharge them 1st. Batteries will lose
>power just sitting. The amount a battery will lose will depend on
>many different things, but for a ball park you can ESTIMATE about
>.1 (point 1 ) -> .2 (point 2 ) volts per day.
2. I have an Avistar Select with OS 40 LA and it seem to take forever to get it off the ground. Running the 10x6 that came with it. Would performanace improve with a 11x5 or 6 prop or will I have to buy a larger engine for it.
>The LA series engines are not powerhouses. What I suggest
>to people is to run a 10" prop on a 40 engine and an 11" prop
>on a 46 for general sport flying. I feel an 11x5 or 11x6 tends
>to load most 40 engines, while a 10" prop does not allow a 46
>to really perform. As with anything there will be exceptions.
>As for your question about the engine, I would suggest getting
>a ball bearing 46. It will provide noticeably better performance
>and if you are worried about flying too fast, that is why the
>throttle is there. Some USER FRIENDLY engines I can
>recommend from personal experience are:
>OS 46AX, Thunder Tiger Pro 46 and the Evolution 46NT. By
>user friendly, I mean that 99%+ are going to run great right
>out of the box, minimal break in is required before being able
>to fly them and very little (if any ) "fiddeling" is needed to keep
>them running great.
Thanks for any and all replys,
Old Man Jim
Hope this helps.
