Hey all.... I really like the C. F. rods and titanium ends for Central hobbies, But
WoW they sure add up fast.... So I have been sticking to the old lo-tech 4-40 rods
they seem to give me all that I need with no problems to date....
I use to also use weather bug... But now just use Yahoo... They all seem about the
same..... But also to date.... The best is when I get up and look out the window
I have yet to be wrong with that method
I was checking/putting back together the Showtime after Gorilla glueing the stabs
on... First plane using that stuff, if it holds good, I sure like using it, just seems eaiser
to work with, and it fills the gaps, not sure it's a good test since there is not many parts
to glue on it.... Anyway, I started to put in this 4.8 1400mha 4c in the "Do" Then
started thinking.... Did I use one of the two new 6v, or did I use the "Do #1's) 6v????
This age thing sure is good... I usually date my bats as I get them.... But not so this
time:-(( I think I used the second bat in my Kat, so I pick it up from the floor and I'm
cycleing it now to get a % on it....
Anyone has an opinion on which charger may be a better choice??.....
Triton or Elite.............................
Ohhhh One more thing.... A Call for HELP.... I'm running out of tape to stick my ant on
the wing[:@]... Anyone see any problems in the pics below that might be the cause of
my intermittent glitch... Foam is off of the rec. for the pic.... Tailwires has no medal to
medal contact now...
