RE: Mind that throttle!
Clayton,
I use 2 old poles from a old bagmitten set. I wrap the upper part in foam then drive them into the ground with a few inches between them. Then u just drop the fuse through the gap with the hor. stab behind the poles. Works great. Any sort of pole, dowel, pipe, rod whatever would work. Few ppl at my club use some that r commercially designed with the same effect. ONe person ues a strap and a screwdriver in a similar way.
-John
