RE: Nitro Rustler Race Set up
Luckly I have an 18 tooth CB. I am running a 20 tooth and 70 tooth spur and I can get ahold of a 68 if need be.
I am running RPM A arms all the way around and the stock shock towers. In the front I have the shocks mounted at the widest angle, roughly 5.5" apart at the bottom and 2 & 7/16" at the top. In the rear there is only one spot to mount the lower part of the shock, but when mounted they are ~7.25" inches apart and on the top I have them mounted on the lowest setting, which puts the shock at more of a wide angle compared to the top mount which puts them almost straight up and down. At the lowest setting they are 3.25" apart.
Is this ideal? Or should I still put the fuel tubing in place?
Also, would a ball diff help?
-bryan
