RCU Forums - View Single Post - Inverted Blues
Old 05-30-2006 | 06:08 AM
pe reivers
Default RE: Inverted Blues
have you tried leaning the main needle? You may be too rich.
It also often helps to connect a vent line to the carb vent hole on the stamped metal plate, and route that in a prop blast shielded "vent box" with constant pressure. A small balsa enclosure in the fuselage will do.
Sometime it is enough to rotate the stamped cover, or cover the vent hole with a prop blast shield.
