RE: Need opinion on first plane
I can comment on the prop selection. You want a prop that can handle a few bumps with the grass without breaking. That means you want a brand called Master Airscrew. For the engine that comes with the plane I would use an 11-5 size. IT will give you lots of pull when you need it to get out of trouble and it will keep the plane from getting too fast. [8D]
