RCU Forums - View Single Post - Mind that throttle!
Old 05-30-2006 | 08:30 AM
go-kartowner's Avatar
go-kartowner
Default RE: Mind that throttle!
My 9C has a throttle lock. Well actually its the idle down but you can set it to idle no matter where the throttle stick is. Then you flip it to regular mode and the throttle stick works again. It's the same switch as the engine kill switch. It is 3 position, up-regular, middle-idle down, down-kill
Karter
