RCU Forums - View Single Post - Model Tech Magic Extra.
Old 05-30-2006 | 09:52 AM
MikeRuth's Avatar
MikeRuth
Default RE: Model Tech Magic Extra.
Easy landing? That's a big prop for that motor!
I found the landings to be a bit tough in no wind condidtions. It drops like a rock dead stick.
I had no bad landings but one a tad rough on the gear and when I inspected the airframe afterwards I found the former at the rear of the wing had come lose from the fuse. Nothing a littel CA couldn't fix.
I also noticed the trim on aileron's changing from flight to flight. and a little CG sensitive. I set mine at 3".
Can you tell if there is any thrust angle on your engine? I mounted mine up on the thrust line and looks like I have none.
It's definetly a fun plane, short 6 minuet flights on that 85 CC tank. I'm running an apc 9X6 and it almost has unlimeted vertical. Tops out about 200'
Did you tach the engine with that prop? I'm turning about 10 to 11K .
