RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 05-30-2006 | 02:36 PM
  #4653
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
rtn9105.... "Do" #2 started life with the tailwires on, so I'll never know... But I have since
switched the cables to Kevlar, and now removed all the medal clevis for plastic one's So
there is no medal to medal at all... Guess it's not as strong either [:'(]... Thanks
Blisster... Thanks for the link..... I'll be taping the ant. to the wing for a bit... It's not all
that bad.... I started this, to get as many opinions as possible... But I guess the consensus
pretty much is some type of shielding for what ever reason... I've pretty much, moved,
twisted, checked, used 3 different recievers, 3 different ext. wires, weaken my tailwire
setup etc. with no change.... Anyway Thanks.... I need a break from it... So I'll just
tape and fly for now.... Then ask.... To shield or not to shield..... I would hate to do it,
and still have the same problem, then find out it was my tail wheel causing the problem
all along.... Hey I gotta go do something
Thanks again........
On a better note... I've cycled the 6v that I had in my Kat... It was only an 1100mah
and discharged from fully charged showed 998/1015... Better than 90%.... It's in the "Do"
charging.... Have one on order just incase....... So both the "Do" and S.T. are ready.....
B Good People...
