RE: Mind that throttle!
at our field we have several PVC U shaped retainers in the hot pits that fit over the rear of the fuse, padded pipe insulation for the tail surfaces ,they slide into 2 pipes sunk into the ground at least a foot. when your finished running up your engine reduce throttle and it just slides out out of the tubes they work well .
