RE: Showtime
Have you checked the travel on the elevators to make sure they are synchronized? I tape a push rod on each elevator and point them past the TE of the rudder then using your TX give up elevator and see if the travel is the same for both if not you will need to adjust them.
I'm not familiar with the 475 how much torque do they have?
Don't give up....once you get this ironed out you will love this plane.
