RCU Forums - View Single Post - Inverted Blues
Old 05-31-2006 | 09:40 AM
Gremlin Castle
My Feedback: (14)
Default RE: Inverted Blues
It sounds like you have not fried a gas engine yet. They can run too lean and damage themselves just the same as a glow engine.
Back to the original problem of running erratic running while inverted there is one more thing to try. Get a couple of helpers that you trust and fire up the plane inverted. If it is still erratic it is most likely a mixture problem. If it runs smoothly then it is still an inflight airflow problem affecting the carb.
ORIGINAL: Artisan
You won't hurt a gas/spark model engine swinging a prop by running it "too lean". Why? Because it won't run "too lean". That is glow fuel thinking. Get rid of it.
