Barry... When I was going to order servo's for the S.T., I was thinking about the
Karbonite gear servos... I called Hitec and asked about them, The tech said the
same thing as the fourm... That they are good in .60 size and below models,
anything bigger go with the M.G. servo's. He said that the Karbonite has not
performed as they expected on .60+ sized models.. Because they are too hard
a gear and on those models the gear will crack and fail....
Great morning for a couple flts. pretty much no wind... One each on the S.T. and
"Do", They both flew Great!!! Then someone flipped the switch... Instant high winds,
Had trouble taking the planes apart without someone to hold it:-(......... Atleast the
battery in the "Do" still showed high in the green after the flt......
