RE: Need help with gas engine glitching problem
I highly recommend the following for any gas engine setup to avoid interference caused by the ignition:
1. use a PCM receyver
2. use nylon push rod for throttle control
3. maintain at least 12 inch between receiver system and ignition system
4. ground the ignition wire to the body of the engine
5. secure any loose wires
--qc
